15X10 Rim
Discussion in 'Wheels and Tires' started by LittleT, Feb 7, 2010.
  1. LittleT
    LittleT Member
    Maysville NC
    1972 Grabber, Gold 1970 Maverick
    I bought a set of Weld rims this weekend to go on my 70 Maverick. The rear rims are supposed to be 15x10 with 5" of back space. I know there are a few ppl here running this size rim. But when I went to bolt them on the tires were hitting my leaf springs. It looks like I need at least a 1'' spacer to make it work. So my question is, what did you guys that are running this size rim do to make it work on a stock 8''? :hmmm:
  2. LittleT
    LittleT Member
    Maysville NC
    I forgot to put the tire size, it is a 275/60/15.
  3. Craig Selvey
    There is no way I would put those rims on a Maverick. They are just WAY too wide to fit correctly and a one inch spacer in my opinion is not safe. Sell theose wheels and take the money and buy a rim that will fit better.
  4. blugene
    Seems kinda big to me. I like em more wide than tall so I run 14's. I had 265-60-14's on my 14x11 rims on back and 245-50-14's on front 14x8's. I personaly wouldn't run spacers, but that's me. Got pics?
  5. 71gold
    that tire needs an 8" rim...then it will pull the sidewall in and make the tire stand up straight...that is the size tire i am running on 8" rims...:yup:
  6. 302-72-mav
    302-72-mav Member
    sactown CA
    i put 275-60-r17 center line's on my mav ( as seen in pic's ) and i had to trim the leaf spring a lil bit to get them to fit // AND put air ride shocks to lift it up so they won't rub
    at SACRAMENTO raceway
  7. LittleT
    LittleT Member
    Maysville NC
    What is the bs of your rim?
  8. LittleT
    LittleT Member
    Maysville NC
    302-72, I just put new leafs on and there is no way I am going to trim them....IMO. But your car does look good :thumbs2:
  9. mavgrab302
    I have 15X10 and 15X8 rims for the back w/4.5 bs .. The 10's are way to big going to send them back.. but with both I had to use a 1/4 inch spacer...
  10. LittleT
    LittleT Member
    Maysville NC
    Did your 15x10 hit your leaf spring with the spacer?
  11. mavgrab302
    My 10 didn't hit my leaf with or with out the spacer... The problem I see is clearance on the outer wheel lip I don't want to jack the rear of the car up for clearance... The outer edge of the 10" rim was almost even with the quarter panel... My 10 is really a touch over 11 inches wide and my 8 is right at 9 inches wide, I didn't know how they were measured.. advertised width is were the tire mounts not overall width...
  12. LittleT
    LittleT Member
    Maysville NC
    Here are a few pics of the rim, I think there will be enough room between the tire and the wheel well. So I think I am going to get a 1" spacer and see if it will work.
  13. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    I would check with wheel manufactures and see if anyone says it's safe to run 1 inch spacers. You putting some power in this car? Hate to see the NICE looking car with beat-up quarters.
  14. LittleT
    LittleT Member
    Maysville NC
    It has lots of power, it is hard to hold the 250 back.....:drive:.
  15. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    I would trade or sell the wheels and get ones to fit without spacers. Some drag strips have flea markets first part of year or may list on racing junk. Good Luck! an hold that 250 back! Good answer you gave!!!!
