Are there any 2bbl carbs that will fit a 200ci to replace a 1bbl carb? If there are, do yall know of any adapters? Thanks, Jeff
I don't know if there is an adapters for a 200. There is for a 250. Changing from a 1 to a 2 brl carb. may decrease your performance of the enging. All the adapter does is plug up one whole. Your best bet is to leave a 1 brl on.
200 and 250s use the same head so the adapters will work on both . Plugs what whole ? A 2 barrel adapter is larger at the carb base and smaller at the intake . Kinda like a funnel . What whole do you think it plugs ? No , there isn`t any 2 barrel carbs that will bolt up to a 200 . You can get adaptors from a cuple places though . For a mostly stock engin you should prolly go with a small webber . The best way to put a 2 barrel on would be to have the top of the intake milled flat . Then drill the holes and bolt it right to the intake . If you`r engin is stock right now you prolly should start with the exhaust . A header and 2 1/4 inch single exhaust system will give you a nice power gain and more MPG too boot ! What year is your 200 ? if it don`t have the DS I or DSII ignition system it would a great idea to put on in it . Here are some great ford inline 6 sites for ya to check out. www.cliffordperformance.com www.fordsixparts.com and a good forum. www.fordsix.com
