05 mustang convertible top starting to separate from the back glass...
Discussion in 'Other Automotive Tech & Talk' started by scooper77515, Jun 9, 2010.
  1. scooper77515
    What is the typical procedure for repairing this? Ford dealer said they don't mess with it and send it out to upholstery shop.
    I was thinking of etching the glass and applying some adhesive, but want some feedback before I jump in and ruin the top.
    Anyone ever fix this issue? :huh:
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I'd say let the upholstery shop do it. They have the experience and right stuff to do the job right. You don't want to glue it then it tear the first time you let the top down....
  3. scooper77515
    How do you find a reputable upholstery shop? I guess I will just ask the local Ford dealer who they send it to...
    I would have never guessed that this was an upholstery job...:hmmm:
  4. mercgt73
    I repaired my wife's fox body back glass with windshield urethane. it lasted for a couple months, but separated again. I would get a quote from a convertible top/upholstery shop. you might get a warranty that way too.
  5. scooper77515
    Well, just an update...We called a couple of Houston's biggest Ford dealers and then called their recommendations, and have gotten 2 answers of "need to replace the entire top" and one woman getting beligerent on us because she couldn't understand why it was GLUED and what we were talking about.
    Got onto the local mustang forum and looked around and have two more hits to try today.
    I told her she should have never bought a convertible...
  6. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    and that's when the fight started!!!!! hee hee
    Good Luck! Hope a simple (cheap) fix,,,
  7. ford84stepside
    Berry Alabama
    Scott, I'm not sure on your's as it's a newer model than ours, but on ours, the back glass has a row of stiching around the back glass. Not really sure how the back glass is attached to the cloth that the top piece is attached to. I do know that big piece is attached with a zipper, so I think just the back glass section can be replaced by it's self. Hope that makes sense, if not I can get you a pic of what I'm talking about.
  8. scooper77515
    Ours appears to be glued from both sides. A layer glued to the inside of the glass around the outside inch or so, then a second layer, the actual top layer, glued around the outside inch of the glass.
  9. ford84stepside
    Berry Alabama
    Yeah, that's different than the one on our fox body. I'd still try the upholstery shop route, at least let them look at it. They might recommend something that will last....
  10. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Just reread and did not see where you talk to glass shop. May want to check with them and see if they have ever replaced a back glass.
  11. scooper77515
    I have not talked to a glass shop because everyone I have asked said to go to upholstery shops.
    I have two phone numbers I will call that have good feeback on the local mustang forum...I just got home too late, so will have to call them tomorrow.
    I originally, and erroneously, thought I could just take it to the local Ford dealer and they would fix it. Was suprised that it had to be sent out, and Ford cannot fix their own stuff.
  12. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i fixed my exwife one time with some spray adhesive from home depot. just had to make sure it was real clean first.
  13. scooper77515
    And it held up?
    Just 3M spray adhesive?
    I am afraid someone is going to charge me a LOT of money to fix this, if I can ever find someone who even agrees that they can do it.
  14. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    mmm I think he's saying he fixed the EX-WIFE,,,,,,,, j/k
  15. fan2488
    fan2488 Member
    spring,TX
    Yes Scott, as far as i know its held up. She hasnt said anything to me that it has'nt. Not sure if she would say anything to me or not.
